Typically YUV is preferred for projectors, so if setting both to YUV works then go with it.Hi all,
I have a weird phenomenon happening between my Sony BDP-S570 Blu-ray player and my Benq HT3550.
For some reason, recently, I've started getting the "purplish" screen that indicates a color space mismatch between the two. Both devices' colorspace settings are on "Auto".
When I change either the Blu-ray players setting to "RGB", or the projector's to "YUV" (either full-range or limited), the problem goes away.
In other words, when the two devices are both set to the same standard (either YUV or RGB), things are fine. But when they're both set to "Auto", the problem is shown.
I just received the projector back from BenQ to have the HDMI board fixed, and it works fine. The Blu-ray player is old, obviously, but works fine otherwise. There was a lightning storm recently, but other than that, I have no explanation for this.
Interestingly, no matter what setting the Blu-Ray player is set to, the projector shows the input as "YUV."
Any ideas?
Joshua
