Status
Not open for further replies.
1 - 3 of 3 Posts
Hi all,
Currently my 9100 developes a faint vertical stripes on right size of the screen. They are off the raster, at the border of the CRT. It's happen on Green and Blue, NOT on Red. The stripe is like video noise, straight down from top to bottom, about 8" wide (on screen). It's very dim, can only see it on screen (actually on wall, off screen) when the image is total dark. But I can see it's there when look thru the lense. I'm not sure it's cause by extreme convergence adjustment ? How to fix it ?
Thanks in advance
Thuan
Make sure that you are not using to much horizontal linearity balance in the alignment menu.
Chip S.
1 - 3 of 3 Posts
Status
