Make sure you have recent ATI drivers.
Make sure it really says 1360x768 in the display properties.
You may have to hit the phase + button in the ATI control panel and restart.
In powerstrip you have to select 1360x768 60hz as a custom resolution (Not from the main screen) This requires two restarts of your computer if you do it right.
Once this is all done you should have a solid desktop at 1360x768.
If not you may have to go into the Input properties for Video7 and have the Sony auto adjust.
Yes you can get 1360x768 without power strip, but you will have banding. Most people won't notice this without a test, but its there.
