1 - 2 of 2 Posts
I am having a hell of a time here. I am trying to hook my new SA-W2500 Sony Subwoofer to my new Sony STR-DG720 receiver. I only have two speakers connected to the receiver at the moment, and they're working just fine. However, it looks like the manual wants me to just use the audio cable that come with the subwoofer to connect to the receiver's Subwoofer Audio Out hole. But the thing is, even if my Subwoofer has a green light where the Power light is, there's no sound coming from it. And I know it works, because when I hover the cable's plug near the receiver's Subwoofer Audio Out slot, it gives feedback.
Would someone mind helping me out? I really need to figure this out in the next couple of hours. Thanks!
Discussion Starter · #2 ·
Nevermind, I got it to work. I just had to set my Front Speakers to "Small" under system in order for the subwoofer to pick up. I guess this will be a good reference for those that can't figure it out.
1 - 2 of 2 Posts
