I've been looking buy 40" - 42" TV for the gym room.
Unfortunately, there are so many choices out there, and so much information, so it is difficult to make a choice. What makes things even more difficult, is number of opinions about different TV's, plasmas, LEDs.
I'd like to spend in the range of $500 - 800 on this TV.
So, after spending some time, I've set my eyes on three:
- LG Infinia 42LV5500 LED
- Panasonic VIERA TC-L42D30 LED
- Panasonic VIERA TC-P42ST30 Plasma
I don't care much about Wi-Fi, because I will connect LG Blu-Ray with built-in Wi-Fi. So, basically this TV will be used for:
- Netfilx
- Network streaming
- Blu-Ray
Are these TV's are on overkill for my purpose, or just about right?
What are pros and cons? Any big reasons why I should or should not consider either one?
Thank you very much!
- Netfilx
- Network streaming
- Blu-Ray
