1 - 7 of 7 Posts
I am looking for a 32" lcd...it has to be a 32" with a max width of 33". It will be used mostly for standard def directv (upgrading to hd in the future) dvds and xbox 360. I also have a budget of no more than $700.
I have read good things about many tvs on these forums but have not had any luck finding these tvs in a local store so i could see them myself. The only one i have actually seen is the Westinghouse 32.
Some of the tvs i have read about are:
Westinghouse
Vizio
Olevia
and an Emerson EWL3706...do they make a comparable 32"?
Which of these should i not be considering, and what others should i be? And which one would i be ok buying without seeing?
The HD tuner won't hurt anything. However, are you sure you have no OTA digital signals where you are? Even if you cannot pick up a usable analogue signal, you might get some digital, possibly even HD, stations. - DR
1 - 7 of 7 Posts
