1 - 2 of 2 Posts
Morning all
I do apologise but I'm a little stuck and i know it ll have been answered many times before but...
I have purchased a Samsung UE40H6400 LED HD 1080p 3D Smart TV with 2 active 3d glasses.
Im trying to use the 3d function and I'm a little stuck with it.
Ive downloaded Big Hero 6 film but unsure the format is right my question is that i got an mkv version that the tv doesn't support i have now realised what format i now need. All films will be played through usb into the tv I've tested normal 2d films and they play fine.
What format will i need to play films using active glasses does it use sbs,uo,avc?
i tried abs format but i didn't work the file size is far less than a abc film format
Many thanks for any help
Danny
Discussion Starter · #2 ·
Morning all
Danny
Thx for replies???
But I've manage to fix the problem and now fully up and running with 3D on smart tv
:confused:
1 - 2 of 2 Posts
