Status
Not open for further replies.
1 - 2 of 2 Posts
Had the installers instal a channelmaster top of the line antenna in today and I could only pick up 1 channel out of 6 HDTV channels. The one that they could pick up dropped out about every 2 minutes and said searching for digital signal. I am about 45 miles from the towers in Seattle, WA. What could you recommend to get to pick up the HDTV signals in my area? Thank you for any feedback. Clueless in Seattle
Search the site here and
http://www.***************.com
We have a number of people receiving all of Seattle's digital channels between Everett and down towards Olympia. Let us know what hardware you have. Receiver, antenna,rotor, coax type and installation including location. is it in your attic,installed on the roofline or on a mast. you may need a mast and rotor to dial in a signal, but your search will yield many successful installations by those determined to pull in a digital signal.
Good Luck
RJW
1 - 2 of 2 Posts
Status
