Hope this is the right section.
I am getting ready to purchase a Klipsch RC-52 center and I want to mount
it on the wall using a shelf above my flatscreen that I have on a stand .
RC-52 measurments show to be 20in-w X 10.5in-d. The shelf i am going to buy is 24in-w X 10in-d. So the width will work for the RC-52 and since the speaker measures 10.5in deep and the shelf is only 10in-d will my adjustable legs that are on the bottom of the RC-52 be hanging off the shelf in the front or back?
If anyone can help me as to where the legs are positioned on the bottom of this center that would help.
Hopefully they are inset about one inch or so that way it will sit on the shelf perfectly.
Thanks in advance.
Thanks in advance.
