Ok, first thank you to Citibear and all who helped me in getting my DVR and stopping me from making a huge money wasting mistake.
Now that I have it set up and just tested it recording to HDD from VHS successfully I have something else I want to try.
I'd like to know if there is any way to record streaming video (HULU, YOU TUBE, etc) to the Pio 460 HDD? I've tried doing by hooking up a USB cable, no luck. I also tried hooking up an S-Video cable and audio cable to the front ports and setting the input to DV Front and still no luck. Is there something I am missing or not doing or something I am doing wrong?
If there is no way of accomplishing this, let me know and I will figure out a way to capture the streams on my PC and then I can just copy them to the DVR via USB doing it like you would another HDD or something. (One can do that according to the manual).
I have another question regarding recording VHS to the 460HK HDD: I tested doing that on the "4 hour" mode and the PQ turned out awful. If I set the HDD record time to 2-hour or less will the PQ be better or is it completely dependent on the original tape? (The tape was recorded on 4 hour mode and plays ok through the TV (although not as good as on my old CRT TV).
Thanks for the help and advice.
