Status
Not open for further replies.
1 - 4 of 4 Posts
I have a Sony DVP-S360 that is about five or six years old. It still works but not very reliably sometimes it will not play a DVD at all and some times the image is distorted by blue blocks on the screen. I think that the DVD drive may be the problem. I have a very limited budget and thought that maybe I could replace the DVD drive myself but do not know where to find the parts of if it is even worth it to do. Can I do this project cheaper than buying a new DVD player? Where do I find the components? What about manuals is there a manual out there that will help me? Any help would be greatly appreciated. Grace to you, C
You're better off buying a new sub-$100 DVD player. The Sony uses proprietary DVD loader and not PC-DVD-ROM so it would be too expensive to worth the repair. Some DVD players are now sub $50 like Cyberhome 300, Apex, Memorex, Magnavox, Emerson. Check your local Wally World, Circuit City, Best Buy, or Target. You'd be surprise how cheap DVD players have become. On line check out the Yamakawa line of cheap players they're great.
old usenet info:
Subject: Re: Auto Calibration on Sony
Newsgroups: alt.video.dvd
Date: 2002-03-16 08:10:21 PST
You can always find plagiarized versions of my original Sony DVD player
calibration instructions. However, the following is the latest version and
it has two new additions which have been written in response feedback that I
have received over the years. Be sure to read the items preceded with
_*** IMPORTANT!!!_.
The plagiarists have been slow to update their copycat versions.
My Sony DVD player calibration has evolved over the last three years and I
have added several additional comments to the procedure. Quite often, people
will use an older version of the procedure and they will not have the
additional footnotes.
The Sony 330, 360, 530, 550, 560 and 570 players (and all others produced
after 1998) have the ability to automatically calibrate the playback
functions of DVDs and CDs. Typically, disk calibration is done only after
many hours of operation, or if there are problems changing layers and/or
accessing chapters or if the unit has been bumped hard enough to knock it
out whack, but not hard enough to damage it. Should the unit develop
playback problems, the disk calibration procedure may save a trip to a
service facility. If you are willing to accept any risks which may be
involved in executing this procedure, the instructions follow.
Before you start, have ready at least two Dual-Layer DVDs and two
Single-Layer DVDs. (Dual-Layer DVDs usually have a gold color playing
surface and Single-Layer DVDs are silver.) You can also run the audio CD
calibration if you want. The reason that I recommend having two of each type
is that the player might produce an error message on one of the disks due to
some miniscule imperfection and you will have another to fall back on. (It
is unlikely that you will have a rare SACD disk so this part of the
calibration procedure should be skipped.)
Before performing any disk calibration procedures, allow the unit to warm up
completely by playing a disk for at least one half hour. Then, make sure
that the DVD player is turned OFF and in the standby mode with the little
red LED glowing above the on/off button. You will be concerned only with
items 1, 4, 5 and maybe 6. To escape from all test modes, press the Return
key.
To enter the test mode, press Title, Clear, and Power on the remote. This
will produce the following menu:
Test Mode Menu
0. Syscon Diagnosis (For technicians only)
1. Drive Auto Adjustment (Automatically calibrates DVDs and CDs)
2. Drive Manual Operation (Prompts before each adjustment)
3. Mecha Aging (Gives technicians auto repeat mode for testing)
4. Emergency History (Shows the number of hours on your machine)
5. Version Information (Shows filmware version)
6. Video Level Adjustment. (Test pattern)
Exit: POWER Key.
Press #1 on the remote and the following menu will appear:
## Drive Auto Adjustment ##
0. All
1. DVD-SL
2. CD
3. DVD-DL
4. SACD
Exit: RETURN
Press #1 on the remote and insert a Single-Layer DVD when the drawer opens.
Press the ENTER key and the machine will begin to calibrate all of the
playback features.
*** IMPORTANT!!! Always do the Single-Layer DVD calibration first, then to
proceed to the Dual-Layer calibration. If you do not do the Single-Layer
calibration first, the Dual-Layer calibration will probably fail. ***
*** IMPORTANT!!! Press ENTER whenever *onscreen prompts* ask for permission
to proceed with a test. Some earlier Sony DVD players will appear to be
calibrating a disk (the numbers continue to flash like an out of control
pinball machine) when in fact, the machine is paused and awaiting a response
from the user to continue. (An often-unnoticed onscreen prompt asks the user
to press Enter in order to continue.) If you do not press Enter at this
point, the machine will sit in limbo forever. ***
When calibration is completed, follow the onscreen instructions to return to
the above menu.
When the Drive Auto Adjustment menu returns, press #3 on the remote and
insert a Dual-Layer DVD when the drawer opens. Follow the instructions as
noted above. When calibration is completed, follow the onscreen instructions
to exit from the Test Mode.
Now you can turn the player back on and try your Dual-Layer disks and see if
the layer change has improved. I calibrated both my Sony 550 and 360
machines, and they are both working better than ever.
If you have any hesitation about trying the service mode calibration, leave
it for an authorized service facility.
March 16, 2002
1 - 4 of 4 Posts
Status
