Status
Not open for further replies.
1 - 9 of 9 Posts
A friend of mine unknowingly purchased a Region 3 DVD from eBay and now obviously wants to watch it. I tried ripping it with DVD Decrypter which seemed to work, but I cannot view the subtitles using PowerDVD XP (the only DVD player I own). Is there some trick? I have looked at the docs at doom9.org to no avail.
Surely somebody has done this successfully before. All I want to be able to do is rip the movie, remove the region, and then I'll dub it to VHS for him.
Originally posted by Hanson
Is it possible that the DVD has no english subtitles?
Almost forgot......under "VTS overview" (in the movies *.ifo file) it will tell you all the audio and subpicture info you want.
Enjoy!
Discussion Starter · #5 ·
Sorry, I should've mentioned that it definitely has english subtitles (even PowerDVD tells me this, but doesn't allow me to select it).
Discussion Starter · #6 ·
Originally posted by nysteelo
Download Ifoedit , open up each *.ifo file, hit the "region free" button, and voila!
Where/when do I do this? Copy the files to the hard drive and then use this tool?
Mike.
I can tell you that I have Cineplayer 1.5, Windvd 4.5 ,Nvdvd 2.55 and powerdvd xp 4.0 and power dvd is the only one that will not show anysubtitles. I have like 10 region 3 movies (HonkKong martial arts movies, Hero, Musa ect..) and Powerdvd will not play the subs....not even on region 1 movies!
But.... You can use Zoomplayer and select the powerdvd filters and Zoom will be able to pull out the subs for you.
Discussion Starter · #8 ·
Thanks for the tip. I will see if I can get my hands on a copy of another player for cheap and go from there.
And all this time, I was afraid I was doing something wrong... argh :)
At the top of the link I gave you there is a "guides" button, scroll down on the next page till you see "Removing RCE protection". This should get you going.
1 - 9 of 9 Posts
Status
