Status
Not open for further replies.
1 - 9 of 9 Posts
I have the RP-82 and the DTS tracks started dropping out. The DD versions work fine, but last week, the DTS tracks lose sound for just a second and then come back on. I have tried a couple of disk and they all do the same thing. I don't think it is my receiver because the signal is never lost.
Is there a recall for this?
Does anyone have previous expeince with this problem?
What should I do?
When does it happen? At the layer change? If so, have you changed any of the settings recently on your receiver/processor?
I have an HK AVR 520 and a Panny CP-72 if I leave a DTS movie on pause for a while I will loose sound. The only way to get it back is to power cycle the 520. This doesn't happen with DD stuff.
Discussion Starter · #4 ·
There does not seem to be any method to why this happens, it is just losing sound for a second or two at a time. The signal is never lost from the receiver. Last night it sounded like the disk was skipping, I know it is not the disk, it has only been played a couple of times (LOTR).
I think the laser is misallingned or a chip is going bad.
This unit is 5 months old, and I don't think I should have to pay for it, I bought it a Ultimate Electronics, but they said yesterday, it would have to go to Panasonic. There is a 1 year parts and 90 day labor. It is $70 an hour to fix the player, so for two hours work, I would have (almost) bought a new one.
What to do?
Premium Member
a dirty lens??
Discussion Starter · #6 ·
How can I clean it??
Premium Member
There is a lens cleaner disk for CD players, you might look around and see if that will work for a DVD player. The disk we have at work has small brushes attached to the disk.
Again this is just a long shot if it will fix the problem.
John
Discussion Starter · #8 ·
roger that! My father in-law has one. I will give it a shot. Stay tuned.
Discussion Starter · #9 ·
I tried to blow out the dust in the DVD player last night using commpressed air (my lungs) and I played Gladiator during the fight sceen and it never skipped. Your theory may be right about the dust.
1 - 9 of 9 Posts
Status
