1 - 1 of 1 Posts
I have Wide Open West cable with their Scientific Atlantic 8300HDC DVR and a new Samsung HD TV.
I have a bunch of VHS tapes that I'd like to convert to DVD and a bunch of mini DV tapes from a Sony camcorder that I'd like to convert to DVD.
I was looking at the Sony VX560 or VXD655 and the Panasonic DMR-EZ48VK. The Sony 655 and Panasonic have a tuner but I'm not sure if I need it or not.
Questions:
1. Do you think I need a tuner in a DVD recorder VHS combo with the equipment I already have?
2. What make and model would you recommend for what I mentioned above?
3. Can you copy VHS to DVD's with a combo unit just by plugging them in? I.E. - Without hooking up to any other equipment or TV?
4. After I record the the Scientific Atlantic DVR there are options to "Copy to VCR". With a DVD recorder will I be able to copy to DVD instead of a VCR?
Thanks for your help. I'm obviously pretty new to this stuff and really appreciate your input.
Steve
1 - 1 of 1 Posts
