Status
Not open for further replies.
1 - 5 of 5 Posts
I am seriously considering buying a HDTV. I have a nice apt, but its a single bedroom and my TV goes in my dining room/family room. I know a good bit about home theater, but I am no expert :)
DLP sets are not in play since they too much. I am going to be using it for mostly DVD's and console gaming - and eventually digital cable.
I am looking at a 42", but am also considering a larger HDTV. These are the models I have to choose from.
Toshiba 42" 42H83
Sony 46" KP46WT510
Panasonic 47" PT-47WX53
Mitsubishi 48" WS-48313
Toshiba 46" Table 46H83
Mitsubishi 42" WT-42313
Sony 51" KP51W5510
Toshiba 51" 51H83
Any advice, discussion, recommendations, expierences or anything about these HDTV's would be very helpful. Anything I should be focusing on?
Not a problem...every1 is new at some pt. :)
My personal preference out of the ones u listed would be the mits models.
I would however try to go with a silver plus (xx413) model because they're much better than the silver (xx313) models.
I have a 65413 and have compared it to a cpl of the 313 models and it had a much better picture.
Good luck!
1 - 5 of 5 Posts
Status
