Originally posted by smb101 Sorry, I forgot to mention that I have the HD package from Direct TV and an XBOX, both of which I use a lot. Do these play a substantial factor in making a decision? |
Originally posted by M Code Suggest that you check out the new Harman/Kardon AVRs, AVR 430 and AVR 630 just demoed @ CEDIA, 430 is $899 and 630 is $1099. They will include the new Dolby HeadPhone, Dolby Virtual, upgradeable to Dolby Digital 7.1, DTS 96/24, AV Sync Delay, RS 232 control and LCD remote control. Also they have a great new, look with a larger BLUE FL display. |
Originally posted by goodrich you can get the HK525 for $611 at onecall.com, they are factory authorized. the HK might have a lower watt rating but is under rated. should compare very well with the denon (trying to be civil). shop the internet, you can find better prices than crutchfield by far. |
Originally posted by wuhoo got any pictures? also a quick question b/c i havent done any research on h/k in a while -- i know they used to have quality control problems, but from what ive read on these forums it seems h/k receivers are among the faves...am i correct to assume that h/k has solved their quality control issues? |
