Status
Not open for further replies.
1 - 1 of 1 Posts
I would like to add a front projection system to my HT and I have the following requirements:
>long throw = 24 feet
>will only be used at night/dark room, 36" Sony XBR used during the day
>viewing distance = 8 - 16 feet
>max viewing angle less than 45 degrees
>need screen recommendation (must be retractable, no size restriction)
>main input sources will be DVD component and DSS S-video
>would like HD/VGA inputs but not required
>can set up with HTPC if that configuration is advantageous
and finally, I am looking for the biggest bang for the least $
Thank you for your help. I am familiar with HT and electronics in general but have very little knowledge re: front projection systems.
cheers
ddodd
1 - 1 of 1 Posts
Status
