Hi and thanks for any feedback!
I have a large-ish open-plan basement (see pic, below) and want to put in a TV and HT speakers (5.1).
I'd like your thoughts on what speakers I should get.
* Within reason, size shouldn't be too much of a problem. I'd be open to floor-standing 'tower' speakers. I could put the surrounds on the wall or on stands.
* My budget is sub-$1000 and I'd prefer to stay more towards the middle of that range (but will splurge if it's worth it)
* I'm not looking for super-high volume or a sub-woofer that will shake the foundations. We have three young kids, and even from the basement the bass sounds seems to be heard all around the house. I'd consider skipping the sub-woofer if the main speakers had decent bass.
* Having said that, I do worry that I have a large room and need a system that will fill it. The surrounds are quite far from the seating area so need a bit of umpf.
From my research, here's my thinking:
* Energy Take Classic 5.1 - good reviews and cheap, but are they too small for the space?
* Pioneer SP-PK21BS - Larger so should fill the room a bit better, still a very reasonable cost
* Definitive Technology ProCinema 600 - Great reviews, a bit pricey, wonder if the smaller speakers will fill the room.
* Polk Tsi series - the 300's plus matching stuff.
I'm not locked into anything though (even the room layout - see this thread for more details) so please suggest anything you think might work.
