I,m changing out my reciever to a Denon 3808ci and need your help.
I have a cable box, a Mistsubishi 73" DLP, Panasonic 5 disc DVD player and a Samsung DVD / VHS combo connected to it.
There are no HDMI's on the components except the TV and it has two.
The Panasonic and Samsung have 5 NCR connections.
It's difficult to get behind both the TV and AVR.
With that said here are my guestions:
1) Just to clarify the Denon give the option to use HDMI or not depending on the device connecting to it. Eventhough the HDMI is labled DVD/TV etc can they be reassigned or are they dedicated to the TV?
2) Denon has 3 zones 2 audio / video and one audio. Denon has conections for a full surround system (front center side rear and sub) and room you two more speakers. How do you connect the third zone speakers?
3)Whenever it calls for a ground should I ground to the surge protector?
4)I have a internet connection that connects to a computer under the tv. Can I split that connection and run a line to the reciever and do I need to add a mac number for the router?
5) How do I connect a PS3?
6) What is the Denon Link connection for?
Its a pain in the snikies to pull it out and redo so I'm trying to get everything connected first.
I really appreciate any help you can give
