Hello all! I'm getting ready to turn on my Denon 790 and do the Audyssey setup, but I need some help setting up my PB10-NSD sub. The Denon manual says this:
When using a subwooffer with a direct mode
Set the direct mode to "On" and disable the volume adjustment and crossover frequency setting.
When using a subwoofer without a direct mode
Make the following settings:
Volume: "12 o'clock position"
Crossover frequency: "Maximum/Highest Frequency"
Low pass filter: "Off"
Standby mode: "Off"
I have the sub hooked up via the low level inputs to the receivers preout.
The sub has a crossover knob and a switch to disable/enable the crossover knob.
It has a switch for "Auto ON" or "ON" (always on).
It has a phase and gain knobs.
So what should I set all these to for my Denon 790 and Audyssey to be happy?
Sorry if anything I wrote doesn't make sense... I spent all day hooking my system up and I'm half sick so I'm a bit worn out.
Standby mode: "Off"
