Not too sure if I was clear or not......
"Your receiver or pre-amp will have at least rudimentary bass management features if it has a subwoofer output as yours does. Depending on your unit, you may be able to (1) send all bass frequencies below 80 Hz (or another cut-off you set) to the subwoofer, (2) send bass frequencies only to your main speakers (do not use the subwoofer at all), or (3) use both the subwoofer and your main speakers to produce bass frequencies below 80 Hz at the same time. Any receiver or pre-amp will allow you to use option 1 or 2 above. Be sure that if you do have your system set to route all bass to the subwoofer that the subwoofer is set up properly (connected to the proper output, powered on, set at the right volume level). Your receiver or pre-amp may or may not let you send bass signals to both a subwoofer and your left and right main speakers; check the manual that came with your equipment to find out about your particular model."
this is from an article I just read....... what I want it (3). Is it possible?
karl
karl
