1 - 4 of 4 Posts
Dear JD, Thanks for your help. I can't seem to figure this one out. Do you think the following set up would work. Run an HDMI cable from the Dell monitor to HDMI Zone Two in the Denon receiver. And then run the speaker wires from the Denon receiver 7.1 channel to the bedroom speakers. Would this now allow me to watch Apple TV on the Dell monitor with the sound coming from the two bedroom speakers while someone else is in the living room listening to a Blu Ray on the HDTV in 5.1 sound? So basically, sending two video and two audio signals at the same time.
Premium Member
Discussion Starter · #3 ·
X3000 ---> Zone 2 (HDMI) ---> Dell Monitor
X3000 ---> AMP ASSIGN ---> 5.1 + Zone 2
Connect Zone 2 speakers to SBL/SBR speaker posts
Set HDMI Audio to "PCM" (p. 173 Owner's manual)
Note: Because the Dell monitor has no speakers, it is unlikely you would be able to play the same source to both the HDTV and the Dell monitor without the audio cutting out to the 5.1 setup in the main zone.
1 - 4 of 4 Posts
