I know other people have started similar threads. I read through some and just got confused. My TV / cable box / vcr was working fine. Now I have a Toshiba D-R7KC. I hooked it up by following the manual. I can change the input device to vcr or the dvd recorder. VCR works fine and I can watch all my digital channels live in stereo sound after switching to the dvd recorder. I cannot change channels with the DVD recorder remote control. Using the up/down channel buttons, I only get L1, L2 and 4. If I use the number buttons then the channel will change but the screen is all blue.
The screen was all black for every channel during the "auto channel preset". It sounds like the recorder is not receiving any channels. That's why the screen is black for every channel during the channel preset. Why? The channels are there because I can surf through them with my cable box remote. So the cable box sends the channels to the recorder and the recorder is able to send them to the tv even though the recorder can't receive the channels itself. That seems like a contradiction. How can it forward the channels to the tv if it can't receive them? Thanks.
