Status
Not open for further replies.
1 - 1 of 1 Posts
I am looking into buying a projector (probably X1 or H20) and am going to ceiling mount it, however due to layout of room, there are only 2 places that I can possibly mount it. 1 would be flush right and the other 1.5 feet from the left side of the screen (opposite end of room of course)
it will be 19 feet from wall (being used instead of screen)
the wall space is 9 feet wide
So basically I need to shift the image to allow it to show on the screen. Will any of the above projectors do this (without ruining the picture) or do you suggest another.
Also which would you suggest (or another projector not named) to give me the best picture DETAIL (want to see ALL of HDTV's res. in the HDTV football games) in my room setup.
thanks,
Jon
1 - 1 of 1 Posts
Status
