Status
Not open for further replies.
1 - 2 of 2 Posts
I need help to choose a graphic card for a media PC.
I have a 17" LCD monitor with VGA/DVI as the control display and I'm planning to hook up a Sony HS10 (DVI; if I ever get it).
The first conclusion was to get a dual DVI card. The only one I found is the Matrox Pharhelia. Sure there is a G550 ... but I'm not sure if I should consider it.
The other idea was to get a Radeon 9500 Pro (ATI or Sapphire).
I could hook up the LCD to the VGA or use a VGA to component for the HS10.
Is there an other card familiy I should consider?
It is important to me that it will work well with an additional tuner card.
There are some posts about issues with ATI 7500 and 8500 cards. Is there a solution for all these problems?
How about HD resolution limitations on the DVI output?
1 - 2 of 2 Posts
Status
