1 - 5 of 5 Posts
I wanted to test some serial commands to my Anthem D2 through Hyperterminal. It has been a very long time since I used this software and I feel lost. I'm sure I set the parameters correctly, but all I get is a blinking cursor. I set the D2 to TX ON and I can see the commands echoed to the Hyperterminal screen as I press the remote buttons. But I can't send it a command. Any suggestions would be appreciated.
do you have the documents for the RS232 protocol? It will help to assist.
do yourself a favor and use a better soft!
download the 30-day free trial of advanced serial port terminal form eltima
and try the basic query P1P? to get the power status of the zone 1 on your D2
1 - 5 of 5 Posts
