Originally Posted by Pure-Evil
i just got a 1015tx from another member here, and i was wondering if there is a way to reset the receiver back to factory default settings instead of me trying to change every setting he has already put in. anyone know? also, is there an ON SCREEN setup area for me to set things up such as a tone test etc? i don't see any tonetest button on the unit or the remote. TIA...and any other tips other 1015tx owners can give me would be greatly appreciately for my setup. |
Presumably you didn't get the manual with the unit. The pdf is available on Pioneer's website. Assuming that it is the same as the 1014, I copied the info from my 1014 manual pdf which I already had:
Resetting the main unit
Use this procedure to reset all the receiver’s settings to
the factory default. Use the front panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the TONE button, press and
hold the STANDBY/ON button for about three seconds.
3 When you see RESET? appear in the display, press ENTER.
OK? shows in the display.
4 Press SYSTEM SETUP to confirm.
OK appears in the display to indicate that the receiver
has been reset to the factory default settings.
For system setup
Press the Receiver button on the remote (the multi control button with the green mark, not the orange power button).
Press the button labeled with green text that says System Setup near the arrow key pad on the remote to enter system setup.
There are a lot of features with little or no on screen explanation. You really should download the manual.
