Hi guys,
I'm in the process of planning my new home theatre upgrade from LED TV to a projector and require some advice. I have a total budget of $3000 but would prefer to keep it as cheap as possible while still having an impressive result. These are my requirements / specs.
1. Will be setup in living room area and will have some ambient light at times.
2. Going for 100" screen (220.98cm x 138.43 cm)
3. projector distance from screen is approx 6 meters.
4. Seating distance is 4 -5 meters
5. Will be running XBMC - 1080P bluray movies mainly
6. Will have occasional PS3 game use (Not often though)
Basically if you guys could suggest a good value for money projector and a method of DIY screen that would be fantastic. I have access to pretty much any tools that might be required for the screen build. I'm looking to have this project done in the next few weeks. Thanks again.
Tony.
Tony.
