Thanks to the gracious generosity of our own MC Maniac I am borrowing a Sony 1292Q to test in my home theatre. Not only did he lend me the projector but he delivered it to my house as well! When my helper didn't make it, the two of us lugged the thing up two sets of stairs to my HT.
I am in the beginning stages of setting it up. I adjusted the universal optical coupling rings to the appropriate settings for the screen size and projector position. I also reset to factory settings.
Following the manual's setup procedure I also set the Red and Blue gun's convergence angle by loosening the set screw and aligning the holes in the appropriate positions for my screen size (110" wide 16:9). What is the best way to change the tube's position? The manual just mentions using a screwdriver.
The problem I am having is that I can't get the red to align with the blue and green. With the cross-hatch pattern up, the red is about 4 inches from the others. Using the keypad I can get it to within an inch or so then I run out of adjustment.
The red cross-hatch is to the right of the others on the screen.
Should I adjust the red's mechanical convergence farther? I would not have the proper holes aligned at that point. Or did I miss something?
I will recheck that the projector is perfectly perpendicular to the screen. I doubt if it was off it would make that much of a difference. But then again I've only taken the first step on the CRT road so I have to not assume anything...
Any help would be greatly appreciated!
