After looking at TV I decided that I would rather go with a projector and move my 55 inch out to to the family room. I would like to put a projector in my bedroom that I can hook to a pc or ps3 or xbox360 To view just movies on Blue-ray and some streaming off of Netflix. I have a budget of about $1000. The wall is about 8 ft wide and 10 ft tall so I have plenty of area to play with solid white. I only have about 8 to 10 ft back to place the projector.
Few question I have should I buy a screen with the white walls if so would you recommend one. I have been looking at the Benq 1070 but im open to ideas on other projectors. Like I said I want to spend under $1000 but i'm also open to buying a better projector if reason are valid. This is not something I will use that often maybe a few times a month. Also for sound I'm open for Ideas. I would love to do some sorta of headphone setup but open to all idea. I have a Bose 123 system but the sound I don't like for moves because of my vaulted ceilings. Also how is the sound in some of these projectors that has it built in? Sorry this is all new to me thanks for your help in advance.
