I have two alpine type s 10" subs, and I want to run them on a JL 250/1 mono amp. How do I got about doing so? I know how to set up and amp wiring kit and all that, just not sure how to wire the subs to the amp to get the best sound
Now Available: Tech Talk Podcast with Scott Wilkinson, Episode 19 Click here for details.
Originally Posted by bluesky636 /forum/post/18257321
You have two choices depending on the speaker impedance and the impedance that the amp is able to drive: Serial or parallel. If you hook the speakers in series, the load impedance that the amp sees is double that of a single speaker. If you hook the speakers in parallel, the load impedance that the amp see is half that of a single speaker. What is the speaker impedance and what load can the amp handle?
Originally Posted by mattfetts /forum/post/18257421
if you don't mind, just google
alpine type s 10 specs
jl 250 1 specs
Originally Posted by bluesky636 /forum/post/18257484
That's something you should be doing.
Originally Posted by mattfetts /forum/post/18257704
haha, i did but reading that means nothing to me sorry so i was hoping someone who can read ohm description and watt output can tell me the best way to wire up my subs :\\
Originally Posted by mattfetts /forum/post/18257855
okay well the JL amp specs are:
250W RMS @ 1.5 ohms - 4 ohms
and the alpine type s 10:
Impedance 4 ohms
Originally Posted by bluesky636 /forum/post/18257905
You can wire the speakers in parallel or in series. To be safe, I would wire them in series.
Originally Posted by Gizmologist /forum/post/18258600
Take the positive output from the amp to the positive of the first sub in.
Take the negative terminal of the first sub to the positive of the second.
Take the negative of the second sub to the negative speaker terminal on the amp.
Voila! a series connection.
In parallel, all negative terminals (amp and speakers)are connected and then all positive terminals are connected.(amp and speakers)
Originally Posted by Easyaspie /forum/post/18260193
Your amp is a very good amp and capable of and designed for operating into loads as low as 1.5 ohms. Definitely wire it in parallel.
If you wired it in series you would be presenting the amp with an 8 ohm load and you would not be getting maximum power from the amp.
This is how to wire it in parallel:
From the amp's + to 1st speaker + then to 2nd speaker +
From the amp's - to 1st speaker - then to 2nd speaker -
Originally Posted by bluesky636 /forum/post/18260500
Although I agree with your recommendation (as I stated in my earlier response), in order for this amp to operate effectively with a 2 ohm load it will require a robust power supply (strong battery) and large gauge wiring (from the Crutchfield catalog: 8-gauge power and ground leads and a 30-amp fuse recommended wiring and hardware not included with amplifier). Based on the questions asked in this thread, I am not sure the OP has the required knowledge to understand what this means, nor the skills to implement it. Hopefully he will read some books to gain a working knowledge of basic electrical theory (impedance, ohms, current draw, wire gauge, etc.) before attempting such an installation or that he consigns it to someone with that knowledge and skill. I would hate to see him damage the amp and spealers, or worse, his car's electrical system, through an incorrect and inadequate installation.
Originally Posted by mattfetts /forum/post/18261510
haha, I was just unsure of the terms parrallel and series wiring.. and didn't understand how to achieve the best ohm load dude. I'm using 4 guage wiring for both power and ground and have a 75 amp fuse
Originally Posted by Easyaspie /forum/post/18264911
Well then it's a good thing he came here and asked us.![]()
Originally Posted by bluesky636 /forum/post/18265562
I still have my doubts about the OP's level of understanding and knowledge. Oh, well. Not my problem, I guess.![]()
Originally Posted by Easyaspie /forum/post/18265635
I am sure he appreciated you trying to help.![]()
