1 - 4 of 4 Posts
OK all you bejeweled 2 fans out there, any way to get a mouse to work with this game?
There are two trophies I can't get. One of them is to complete level 5 on action mode and the other is to have 5 hypercubes on a single board. I guess I'm not smart enough to figure out how to get the 5 hypercubes on a board. But I think if I can get a mouse to work in this game, I can get past level 5 on action mode.
Any tips would be much appreciated.
Mike
Can't help you with the mouse question...
Those two trophies were my last two, also, and real pain! For the five hypercubes, use classic mode and when you do get a hypercube, try your best not to use it or blow it up. It will roll to the next screen if you finish the level, so you can keep going. Once I figured this out it took me two or three tries and I got it.
The action is half skill and half luck. Try to get a hypercube and use it if the timer goes below half, but try to get it to roll to the next level if possible. Once you get to level 5 if you don't clear it out within the first 10 seconds you are toast. When I won I had two hypercubes rolled forward from level four and I used them both right away.
Have fun!
Discussion Starter · #4 ·
Have fun!
AHHHHHH!!!!
I didn't realize the hypercubes roll over. Awesome. Thanks for the tip Jeff! That will definitely help with both Trophies.
1 - 4 of 4 Posts
