1 - 7 of 7 Posts
Hey guys. Been searching for a projector that fits my needs for couple days now and it brought me to this forum so I decided to create an account an ask here. I have zero knowledge about project and all I got is a budget of $600 for project that is to be used for movies and some gaming. I have a pretty small room and the space I got is about 80' diagonally which is where I plan to set the projector to. There are many options for my budget and I cannot decide which one to get. Could you please help me out and give me an idea on which one I should get. Thank you.
Check out the Optoma HD141X. It sells for between $500-$600, has 3000 lumens, 1080p native resolution and some pretty good reviews online
Discussion Starter · #3 ·
Thank you. After few more research, I found out that the BenQ W1070 is the popular one and is also few bucks away from my budget. I might be going to that instead since most of reviews says it is good for gaming because of low latency. Right now it's $655 at amazon.
The W1070 is the best looking model under $1,500 by most accounts and reviews. It's certainly 'the' projector to get and offers a true 1080p image. The reality is that your budget doesn't actually offer you that many 1080p choices. You get a lot of non-1080p models, but not many 1080p models.
http://www.projectorcentral.com/pro...jw=&pjh=&td=&is=&i=d&tr=&oop=1&sort=pop&sz=15
Just 2 actually (though others may be on sale under $600).
But, add $100 or $200 and your options go way up...
Still, it is the W1070 which delivers on the goods for the money.
http://www.projectorcentral.com/BenQ-W1070.htm
Make sure to read reviews, understand what throw distance, lens offset, and lens shift are before you purchase to be sure the projector will fit in your room properly.
Discussion Starter · #6 ·
Hey guys. So I installed it on a wall shelve above my television. Now when I project it on the wall parallel to it the image is too high that I have to place the projector facing downward which is I think a bit of risky cause it might fall. Can I just place the projector upside down on the wall shelve and maybe secure it with some velcro or anything? Would that be fine?
Discussion Starter · #7 ·
PS: So I did placed it on the wall shelve upside down with two feet that I attached to the shelve and it works perfectly. I like this one better than the previous setup. This one looks secured than what I did first. Only thing I needed to do is to change the position on the settings. :)
1 - 7 of 7 Posts
