1 - 4 of 4 Posts
Hi,
Just got done putting together all the parts and installing Vista ultimate 32bit.
List of parts used:
* CPU: Pentium Dual-Core E5200 2.50GHz Socket 775
* Motherboard: ASUS P5Q-EM Intel G45 chipset microATX
* Memory: A-DATA ADQVE1A16K DDR2-800 2 x 1GB Kit
* Graphics Card: GMA X4500HD (integrated in the motherboard chipset)
* HDD: Western Digital WD6400AAKS 640GB SATA
* PSU: 80 PLUS 380W ATX PSU (included in the case)
* Case: Antec NSK2480
* Blu-ray HD DVD-Rom: LG GGC-H20LK
btw, Thanks to renethx!
Before posting this thread I've searched thru this section in a hope to figure out which codec to install.
Since I built this HTPC for a family member I want to keep it simple, I don't want to install any codec packs that will cause him problems.
Using above Blu-ray player movies from video store play perfect without stuttering.
I was not able to play .mkv and xvid/divx files.
1. My question is should I only install ffdshow ?
2. I've read one post here that says ffdshow uses lots of computer resources?
3. Any similar experiences, what did you end up using?
For MKV you need the haali media splitter. That and FFDShow should be enough for 99.9999999% of the files you are going to ever play back
Discussion Starter · #4 ·
Thanks guys!
Any basic/simple guide for FFDShow ?
I found one posted here is for me at least very advanced/complicated.
1 - 4 of 4 Posts
