1 - 2 of 2 Posts
I have a Control4 home theater controller in my garage and a Control4 mini touchscreen by my front door. The touchscreen is not powering up. There is an ethernet cable plugged in to the back of the touchscreen.
The home theater controller has a power and link lights on but no data light is on. I can work the system with the remote.
Any ideas?
Thanks in advance.
Phil
It probably requires POE (power over Ethernet). If your network switch doesn't provide POE then you will need a POE injector between the switch and the device.
1 - 2 of 2 Posts
