1 - 3 of 3 Posts
hi, i downloaded the iso file and i need help burning it to a dvd .i have never burned a dvd before . i am using windows vista .i downloaded the file the zipped file and than i clicked on it and extracted all files than what do i do? thanks alot.
Download some dvd burning software or your computer probably came with something if it came with a DVD burner. With most DVD software all you need to do is drag the .iso file into it and it will start burning it.
YMMV. Some merely transfer the ISO file onto the blank DVD. I'd suggest Image Burn for a freeware option.
http://www.imgburn.com/
-Pedro
1 - 3 of 3 Posts
