12 years ago we had a custom cabinet built into the alcove space in our new house. Back then the TV was a 4:3 Mitsubishi projection. Five years ago I bought a 50" Sony SXRD which barely fit into the space. Now I am getting that replaced under Sony's replacement program for these defective optical blocks with a 55" HX820.
So my problem is I have this huge hole in the cabinet and a 1.5" thick new TV coming. Given that it's now 55" it will sit just out side the hole and rest just barely on the two vertical columns on the left and right side of the opening. The cabinet itself was built into the alcove space and doesn't go all the way back to the drywall. It's about 2 inches short of the drywall. The walls of the cabinet are made of MDF and I doubt they would hold the weight of the TV (51 lbs). The other problem is that the distance from the outside edge to the back of the cabinet is just shy of 30".
Please help me figure out the best way to mount this new TV. I have seen a Videosecu mount that extends up to 31" which may work if I can figure out a way to secure the mount to the back of the cabinet but I'm open to other ideas. Thanks for the help!
