1 - 3 of 3 Posts
· Registered
Hi guys, I am new to this forum and I was hoping you could help me with some issues on my HTPC that I just built.
HTPC specs:
Intel E6300 ES 1.86Ghz
MSI P7NGM-Digital (GeForce 9300)
2GB Micron 667mhz
X-Fi XtremeGamer
Hauppauge WINTV-HVR-1800 MCE
Antec Fusion Case
500GB Seagate 7200.11
Vista64
Home theater consists of:
42" Samsung 1080i Plasma
Onkyo HT-SR700 HTIB (set up as 5.1)
DirectTV satellite box
HTPC
XBOX 360
Logitech Harmony 880 Remote
IcyBox NAS (Seagate 1TB for storage)
Pics of my setup:
The issue that I am having is the following. When I set up the Logitech Harmony 880 Remote to use my HTPC as an activity (switch to HDMI on the TV, to VCR/DVR on the Onkyo receiver, TV On, DirectTV satellite box On) I am able to switch channels on the DirectTV box using the Harmony remote.
However, the Hauppauge WINTV-HVR-1800 MCE kit wants me to use its own remote for switching channels and such on the PC. This makes things really annoying and complicated as it wants to switch channels by itself on my DirectTV box when trying to watch a channel or record something in MCE.
How can I record shows and watch TV on my PC without using a second remote? The whole point of buying the Harmony remote was to eliminate all other remotes in the system.
Thanks for the help!
· Registered
I'm confused -- are you trying to tune via DirectTV or via Hauppauge when using your HTPC? If for some reason you want both, there's obviously only one set of Channel buttons. Regardless, you can tweak the 'soft-keys' to include any function from any remote. For instance, when I select "Watch a DVD" it switches the TV video to my HTPC, sets the Channel buttons for my Hauppage, sets the Volume buttons for my receiver, and sets the soft-keys for the BeyondTV "On/Off", the receiver's audio-input toggle and the TV's 'HDMI-2' input (those last two are quick-fixes in case not all the inputs got triggered properly).
1 - 3 of 3 Posts
