Status
Not open for further replies.
1 - 2 of 2 Posts
· Registered
I was trying to fix an overscan problem the other day (using the information found here: http://www.avsforum.com/avs-vb/showt...0&pagenumber=1 ) and I'm afraid that I got my self in over my head. After doing some adjustments I've ended up with with a geometry problem on the bottom few inches of my display; everything curves to the right. Maybe I just haven't noticed it in the past, but I'm pretty sure the problem started when I made my adjustments. So I'm looiing for some help on how to either:
A) adjust the geometry problem without further screwing up my display
or
B) restore defaults
(Yes, I know I should enlist an ISF pro. but it's not in the budget right now)
· Registered
Can you post a screen shot?
I have never seen any 'restore defaults' regarding geometry on any TV.
1 - 2 of 2 Posts
Status
