I have read through countless threads, and
still can't determine the best speakers to use for my
surround channels and exactly where to locate them. Part
of the problem is that I haven't come across a configuration
that resembles mine exactly.
Details of my set-up:
o 5.1 DolbyDigital/DTS using core audio from BluRay
o Room dimensions are 15' wide x 20' long x 8' tall
o Front speakers are 9' apart on 15' wide wall
o Front left and front right are Proac Tablette 50
o Listening position is 14' from front wall, 6' from rear wall
o Due to room layout, surround speakers must be mounted on
rear wall
o Rear channels will be used primarily for movies, and
very rarely for music (SACD, etc)
I currently have in-wall wiring run to the rear wall. Two
single-gang boxes contain the wire, one for the left surround
and the other for the right surround. Each of these boxes is
located 7' high and 3' in from each corner. I am willing to
relocate these boxes if it will make a substantial difference,
but they must remain on rear wall.
Please advise as to which type of speaker (monopole, dipole,
bipole, other?) would work best, the preferred mounting
location, and the direction the speakers should be pointing.
Thanks in advance.
rear wall
Thanks in advance.
