1 - 8 of 8 Posts
Hello, i am trying the button learning feature so i can use my tv remote functions with my mr7. It wont program!
I have a 42 element lcd hdtv. I programed my tv to turn on and off and volume but want to add the source button. Also for my sound system, i have an accuran sound system, can in have it under AUD or AUX?
I have run into commands that remotes like the R5, R7, R7W, and Gamer could never learn it no matter what I have tried. But other URC learning remotes like RF10, RF30, or mx-600 had no trouble learning these commands. One such command was the refresh command off IR keyboard used by msntv2 terminal. which I'm using to write this post with.
Discussion Starter · #6 ·
Can u edit button names on the rf 10? I just bought it. Tht wouldnt be a deal breaker i just want it to work. I had a mx500 and absolutely loved it! But it broke after 8 yrs lol. And money is just a tiny bit short right now lol.I am going to return my wr7
No, not on the RF10. The RF20 & RF30 yes. The RF10 will never run out of learning memory.
Discussion Starter · #8 ·
Thats cool, i just read the manual for the rf10 and yes ill be very satisfied with it. I will be able to use the learning feature for my sound system as well. Thanks for your help.
1 - 8 of 8 Posts
