Status
Not open for further replies.
1 - 4 of 4 Posts
I was wondering if the NAD upconverts an incoming S video signal going into the Satellite Input to a Component output going to TV? I had my Panasonic tv, Hughes receiver and NAD 762 connected with S video and since I had a set of componet cables around I wanted to try it, but there is no signal whatsoever. The TV does recognize that component is connected on the back, but there is not even sound coming from the speakers.
How do it set this up??
Thanks in advance
The 762 does not upconvert to component. I believe it does do composite to s-video.
Discussion Starter · #3 ·
Thanks, you save me time waiting. To disconnect component I go, put S video again...
But if have DVD w/ component as well as Receiver with component going into the 762 then I USE the component output instead of monitor out right??
Actually, it does S-Video to composite, not the other way around. I tried composite to S-Video and it looks awful.
1 - 4 of 4 Posts
Status
