Need help with new TV
242 Views 1 Reply 1 Participant Last post by  JoeTV
I bought a new TV last week, a Mitsu WD62628. I was having a problem with it, or so I thought. On HD channels only, I would lose audio on every other channel. Mostly when I would go ch up/down. Then occasionally the audio would mute then would come back as distorted, static.
I had the store bring me a new TV and the same thing happened.
I now believe my B&K Ref 30 is at fault. This only happens when listening via the digital coax into my Ref 30, I get good audio if I use analog cables and/or the TV speakers. I have changed the cable half a dozen times using a very good name brand cable to a plain Jane video cable, same results. I have also used several other inputs with the same results.
Any ideas? Does this sound like a known B&K issue?
What do you suggest I do, the Ref 30 is still covered by B&K warranty, but I would rather not disconnect everything and be without it for who knows how long if I don't have to.
I did not have this problem using a Zenith DTV1080 STB with same cable on same input.
Joe
Status
Not open for further replies.
1 - 2 of 2 Posts
Nothing???
1 - 2 of 2 Posts
Status
