1 - 3 of 3 Posts
Discussion Starter #1
I will soon be painting my theater room. I have a short door that leads to attic space on a side wall. It is currently painted white with white trim. My plan is to paint the trim the same flat or matte color I select for the walls. However, it seems there should be other options for the door itself other than painting it the wall color too. Door Size is 31 3/4 wide X 63 H.
Grayscale fabric printed poster on a very thin backing board? Then a hole cut out for the knob?
Any ideas?
Don't know why the image rotated counter clockwise
1 - 3 of 3 Posts
