Hello to all on the forum.
I have a Pioneer dv-59avi and a Virtuoso HT720 projector purchased through the AVS power buy!
I am having a problem getting the 59avi to use the hdmi connection to the projector. I purchased a Gefen 4 in 1 DVI switch so I could run both my Satilte receiver and the dvd player through the DVI cable to the projector. I purchased a HDMI - DVI cable from better cables as well.
It seems the dvd player does not recognise the projector at all. However I can adjust the dvd players adjustment menus, the hdmi section is grayed out. I have had no problems at all via component video. I even tried to directly connect the dvd player to the projector (ceiling mounted, not an easy task, balancing a $1000 dvd player on top of a ladder!) and the same result.
I should also note I am using the 59avi with a Pioneer 49txi receiver with ilink.
Any sugestions???
I am planning on un plugging the dvd player overnight and try it in the morning.
Just when I thought I had the final piece to my home theater puzzle solved..... a wrench gets thrown into the works.
Thanks in advance,
Glen C.
Any sugestions???
Thanks in advance,
Glen C.
