Status
Not open for further replies.
1 - 2 of 2 Posts
In the installation process after focusing the lenses I am to centering the rasters on the crt face. Shifting the rasters all the way right and all the way left the raster is bigger then the crt face
up and down no problem. Has anybody had this problem and how do you fix it ? also when focusing the the red and the blue
projected crosshatch pattern was way out of focus on the corners
is there another adjustment to correct this. any help would be appriciated.
Thanks Rich
Hi
I had the same problem and it is frustrating. See this post it might help: http://www.avsforum.com/avs-vb/showt...ghlight=raster
As far as focusing the the red and the blue corners... might be astig or probably scheimflug (sp?) but I'm still in the process of learning and perfect those adjustments. Hopefully some of the veterans will ring in.
Good luck!
1 - 2 of 2 Posts
Status
