1 - 2 of 2 Posts
Hey there fellow enthusiats! I need your advice on replacing my MX3000 remote. It crapped out on me after 7 years of good service so it is time to start exploring options.
Currently - it runs the following:
* SIM2 D80
* Integra 7.8
*Sony BDP S1
*Atlantic Scientific Time Warner
*X Box'
*Graphic Eye
*Velodune Subwoofer
What would you recomend to replace it? I like programming but understand anything newer from URC required an installer to program because the software is not conusumer available. I also like RTI and Control 4 but same thing for software from what I understand.
What are your thoughts?
You can upgrade to a new urc remote. Mike over at surf remote central has good prices and will give you the software if you buy from him. I still like the hard buttons of the mx 980. The mx 780 is more limited but easy to program. The mx 5000 allows two way communication but is rather expensive. I really like the mx 5000 but it probably overkill. Another option is a touch based option such as Irule or roomie. Both use your phone or tablet as the remote. I think these are a pain to use as primary remote without any hard buttons like your old mx 3000.
1 - 2 of 2 Posts
