Greetings
Default values don't exist. All the sets coming out of the factory have different settings. Default vaules as found in service manuals are merely a starting point and nothing more. No set that leaves the factory has these default values any more.
Easier to stick a test disc pattern up there and fix the stuff yourself ... one parameter at a time.
A disc like AVIA or DVE has overscan patterns and that is where you would start to fix this stuff.
Regards
Regards
