80 Hertz is a great place to start. Max the subwoofer crossover.
Do you mean max the sub crossover or cut off? It's 2 separate settings. Everything I have read says the sub crossover should be set to 120 Hz.80 Hertz is a great place to start. Max the subwoofer crossover.
Max on the back of the sub knob. In the AVR settings leave the “LPF for LFE” at the default 120Hz.Do you mean max the sub crossover or cut off? It's 2 separate settings. Everything I have read says the sub crossover should be set to 120 Hz.
