  • Take part in a short activity and share your valuable opinion on new design concepts for AVSForum! >>> Click Here
Need help with signal loss
487 Views 2 Replies 1 Participant Last post by  John Habeib
Hi guys,
long time lurker, first time poster in need of help.
I am attempting to wire all my gaming systems so that I can access them all by simply turning on a few switches without having to plug/unplug anything. I came up with the following system (see diagrams below):
All my routing is good, and I'm getting the right sounds from the system I want, when I select the correct routing. My issue is Video. On all the Sega consoles I'm either getting a black screen, or black and white, or colored for 1-2 seconds then Black, or sometimes the image is scrolling. I have the same issues for basically all RCA/Component connections with a few system working properly like the N64. When hooking the systems directly to the receiver or the radio shack switch they seem to work properly. Here's a list of the hardware:
Most of my wires are from Monoprice but some of the RCA wires I picked up from https://www.amazon.com/gp/product/B002P8WME2/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
The radio shack switch is : https://www.amazon.com/gp/product/B006PIPOBQ/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
Monoprice Switch: (Can't find this online, I bought these years ago.)
Component cables: https://www.amazon.com/gp/product/B003L11EWS/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
Receiver: https://www.insigniaproducts.com/pdp/NS-R5101HD/9320335
Projector: https://www.projectorcentral.com/Acer-H6510BD.htm
I used one of those pelican switches(unpowered) before I bought the radio shack, which had the same results. I thought going with a powered switch might help, but it didn't. In fact the ps2/sega saturn worked with that switch, now they don't with the radio shack. I'm not really sure what is causing this issue, but any help would be highly highly appreciated.
See less See more
1 - 3 of 3 Posts
Here's the switches.
See less See more
2
1 - 3 of 3 Posts
